i have down loaded the movie only reg hack' windows says it has installed into the registry.
problem is when i run instant copy 7 i can't find the customize disc screen,what i'm i doing wrong?
could someone please confirm exectly how to install the hack and access it in instant copy.
i would be very gratefull
thanks![]()
Results 1 to 15 of 15
The method I followed was to change a setting in the dvdmagic file.
Prior to making the change, I could not deselect titles, they were grayed out or unselectable. After changing the registry the boxes and check marks in the title selection area are activated and selectable.Jim -
Search your registry for DVDMagic. It should be in there twice. Change the setting to 1. The default is 0.
hi
i've just done that and the value is 0x00000001(1)
if this is correct how do i access the customize disc screen?
thanks -
If you are refering to the window where you can lower or pump up the % of each title. You have to choose Custom Resize I think. You have to saved the image first, then the screen will pop up. Hope that helps.
dhluke -
thanks
i'm using decrypter to rip the dvd then in instant copy i select the video ts folder where decrypter has stored the files then i select the desination folder where i will store the image to burn. so are you saying i need to create the image first in instant copy, then the hack screen should appear?i find the guide not very clear about this -
Check custom resize, and on the page that shows you all the titles on the DVD, highlight the ones you want to change the size for. A slider should show up in the left pane with a video preview windows at the top. You can also uncheck the titles you do not want to have on the DVD.
What do you mean by the registery? Where do i find it?Originally Posted by digitalmaster
there are many who say they can't get it to work. You need do do three things..check version #, registry hack, choose custom resize
http://www.mrbass.org/instantcopy/ -
Why not use IFOEdit to stream process your movie first; It creates new IFOs. Then load your project into Instant Copy and it will do the movie only for you... no registry hacks required... I used this method once when I wanted to compare DVD2One with Instant Copy... it works...
Although it creates an extra step, its alot easier than hacking your registry... just a thought... -
cracked it!!!
i have been ripping only the movie ,i've just ripped ever thing on the dvd then started instantcopy and when i pressed start, up pops the new menu.
thanks to all who replied to my post
Originally Posted by mrbass
Okay i downloaded that little file for the hack.When i clicked on it,it asked if i wanted to move it to the registrey and i clicked yes.I assume that was the correct way to do it.As it now works fine and allows me to deselect the gray boxes in instantcopy!
Yes! Thanks!
Although i wonder why the little gray boxes were not free to deselect to begin with.Must be a bug in the trial demo
With InstantCopy nobody wants to have to fool with IFOedit or any of those other unescessary programs anymore.Originally Posted by ShibaInu
As instantCopy is the Perfect All-in-one tool.It even handles the burning
Not really.All i had to do was download a tiny file and click yes when it asked to be moved to the registrey.Now everything works fineOriginally Posted by ShibaInu
I had the same problems & questions as hawklight. I found all the answer in this thread.
Under the "DVD Tab", I choose "Customized Resize" in the Copy Method drop down box and when I hit the "Start" button, after I navigated to the IFO file from a full rip folder of the original, the "Customize disc" window popped up and I was very happy.
LG RC278 (RC-278) DVD-RW/VCR Hack Options - Copy Protection question
By vicctor in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Sep 2013, 16:31 -
help: my copy wont reg it say problem when registering
By besty01 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 21st Nov 2011, 12:38 -
SVCD2DVD Reg -3 times
By dr4son in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st Oct 2009, 18:45 -
By duzmor in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Sep 2009, 05:59 -
reg the application to use
By liddu in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2007, 04:31
