I've been done some DVD-ripping and converting to DivX with VirtualDub. I've resized the output (decreased horizontal/vertical resolution equally of course), however the final output looks a bit stretched. How come? I know that DVD is meant to be watched on standard TV, but how do I fix this properly for watching on my computer screen? There is no aspect ratio stuff to adjust in VirtualDub?
On 2001-07-06 04:16:03, mogge98 wrote:
I've been done some DVD-ripping and converting to DivX with VirtualDub. I've resized the output (decreased horizontal/vertical resolution equally of course), Dub?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Do you mean substracting the same absoltute # of pixels from each dimension? The the resulting aspect ratio gets crocked. You should try to maintain the same ratio between horizontal and vertical resoltion.
Ralf
Using VirtualDub to Fix Aspect Ratio
By Djard in forum EditingReplies: 15Last Post: 10th Sep 2013, 17:33 -
Aspect Ratio setting in VirtualDub Capture mode
By alesco in forum Capturing and VCRReplies: 34Last Post: 6th Feb 2012, 09:23 -
Pixel Aspect Ratio in virtualdub
By wabsnazm in forum Newbie / General discussionsReplies: 6Last Post: 10th May 2011, 15:57 -
VirtualDub aspect ratio
By MarioB in forum EditingReplies: 3Last Post: 1st Dec 2009, 18:16 -
Aspect ratio problem using virtualdubmod or virtualdub
By anindyanuri in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 08:31
