I imported 1 video clip into MovieFactory 2 and created 10 chapter stops for this 1 clip. MovieFactory also created an initial menu with just a chapter link to the clip. When you click on that chapter link, it then takes you to the next menu with my 10 chapter stops. Is there any way to get rid of that first menu ?
Not sure (you can get rid of the second though!).Originally Posted by lrmcpham
On the "Add Video" screen, did you try checking "automatically play initial video" (wording may be different). This will deactivate the main menu (as long as it contains a single entry and will play your first (and unique) clip on load ... I don't know if this also deactivate your chapter menu or if you can reach it pressing "menu" on your remote.
Good luck. Do inform us. -
You will need to extract 10 separate videos out the movie to do it that way and not use the chapter setting. This way you will have ten separate movies(chapters) on the first page and no submenu with chapters.
ouch ... I was afraid you would say that ...
... I'll put in a suggestion to Ulead for this feature ... seems easy enough for them to add ... thanks for the help.
Where to download menu templates - Corel DVD MovieFactory 7
By Roundabout in forum Authoring (DVD)Replies: 4Last Post: 13th Feb 2011, 17:59 -
moviefactory 6 plus problems
By steenuil in forum ComputerReplies: 0Last Post: 3rd Feb 2010, 07:35 -
dvd moviefactory 5
By bigz704 in forum Newbie / General discussionsReplies: 0Last Post: 24th Sep 2009, 15:54 -
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42 -
Ulead MovieFactory 6 Menu problems
By cheeseandcrackers in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2009, 01:59
