Can I get a clear answer on the best way to convert type 1 DV AVI files for conversion to a DVD. I know my source material is bottom field first and that I should check the top field first box in CCE. If I encode my videos this way do I then still need to use pulldown.exe on the resulting mpv video files. I use CCE 2.5 and there is a 2gb limit on the files. Is there a good way to frameserve these files to CCE.
Use AVISynth, or VirtualDub to frameserve to CCE (check the guides section). I'm assuming the 2GB limit your referring to is due to your OS? If your using Fat32, the size limit is actually 4GB, not 2. If your still on Fat16, then your stuck at 2GB.
CCE version 2.5 doesn't have a size limit that I'm aware of (can someone verify?). You may also need to convert your Type 1 avi. I seem to recall that CCE chokes on type one DV, but I may be misremebering. Search the tools section for a converter.
For your pulldown question, assuming your video is interlaced 29.97 frames per second, then you do not need to run pulldown. If your video is 23.976 frames per second, then you will need to use pulldown.Impossible to see the future is. The Dark Side clouds everything... -
Previously PureMotion included a freely distributable DVtype converter in their editstudio trial as a standalone executable. Now its a dll that is accessed from inside their program. If you could find the original that would work. I have it at home but not at the office or I would send to you.
A better solution is an upgrade to CCE 2.66 as it no longer bitches about type 1 or type 2 dv.avis and now reads virtuldub .vdrs When combined with virtualdubmod for mpeg2 avisynth is no longer required. Its a good thing! -
The converters are freely available for Type 1 DV. Try here:
http://www.canopus.com/US/Products/DV_Codec/pm_dvcodec.asp
and here
http://www.ulead.com/download/dvconverter/dv.zip
Both are freeware.Impossible to see the future is. The Dark Side clouds everything...
Editing AVI type files
By Robertos in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2011, 10:22 -
Burn .avi files as what type of dvd for playing on PS3
By VenGeanCe in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2010, 17:56 -
Question about which AVI type in Total Video Converter plays in DVD player
By jimdagys in forum Video ConversionReplies: 2Last Post: 22nd May 2008, 07:37 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 20:16 -
What type of files is cd ?
By 90blackcrx in forum Newbie / General discussionsReplies: 8Last Post: 11th Jul 2007, 19:49
