I've ripped a few dvds using this guide...https://www.videohelp.com/sefy/?id=ClassicalGuide.html. The first few svcds were really good but the ones that I have done lately have picture breakup(looks like little annoying glitches that pop up every few minutes). Any suggestions?
I had a similar problem it stuttered/glitched every few seconds. There are two things you can try
1. Make sure your dvd player can handle the bitrate that you encoded.
2. Try changing the bottom field b to top field a.
Changing the field order worked for me. I saw it in another post so I tried it and it worked
Good luck
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
Here's what I have figured out. I had been using sti cdrs(which I bought very cheap) and they worked with no problems. I began to have problems when I began using Phillips cdrs. I also noticed that the svcds that I had problems with on my apex 1100 work fine on my friends mintek player. Any suggestions and what cdrs do you recommend?
Thanks again! -
I have heard that some machines don't like the cd-rs that have a slight blue or green color to them.
My suggestion is to read about your dvd player in the "dvd palayer compatibility" chart look left there is a link.
Hope this helps
Signed
Blu-Ray Rip Audio Sync Problem
By kerb in forum Blu-ray RippingReplies: 0Last Post: 7th Jan 2012, 10:44 -
resolution (?) image squashing problem with DVD rip
By suburban100 in forum Authoring (DVD)Replies: 9Last Post: 13th Sep 2011, 19:24 -
forced subtitle problem in avi.net with dvd rip of main movie only
By nathanm in forum SubtitleReplies: 0Last Post: 30th Apr 2010, 09:37 -
Help! Cannot rip this DVD - wierd problem...
By Comfy in forum DVD RippingReplies: 2Last Post: 8th Dec 2009, 10:10 -
Frame Rate Rip Problem
By privateapples in forum Blu-ray RippingReplies: 0Last Post: 11th Oct 2008, 20:26
