this is bizarre, this unit has worked once, and only once. i'm trying to use it now in a clean install of 2000 (it was in 98 before) but it doesn't seem to be working. after i've installed the OS 2000 should be able to record DV files with any more help, right? so i've got sceneanalyzer....and it can't read my converotr! whats' going on? where should it appear in the 2000 control panel anyway?
found the problem, all i need to do is unplug the device, wait 30 seconds, plug it back in, and windows picks it up. whatever...
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Capturing with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2009, 21:55 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 15:15 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 18:24
