I have instantcopy ver 7.0.0.91 on my pc running winxp sp1..im trying to do Babershop dvd..im ripping the movie using DVD Decrypter to hard first and then using IC to make a image to the hard drive...everything starts fine and seems to go almost through the movie with 77 mins left and then the program crashes and the windows "send to MS" box comes up... ive tried it about 3x and i even formated my drive and reinstall xp..i used a fat32 and now im using ntfs nothing seems to work..I did The Generals daughter and that one worked fine...so i dont know if its the movie or what...are any of you guys having the same problem or what...
It seems as though the program is very buggy. When it works, it works great! I tried 2 movies, Harry Potter and Lord of the Rings....and it kept crashing for LOTR but worked flawlessly on Harry Potter. What gives?
I ripped using Smartripper and had Instant copy write to an image on my hard drive. My system is an athlon Xp1800 using W2K, NTFS. -
InstantCopy has problems backing up certain movies, there is nothing you can do about it right now to get them to work.
Reservior Dogs
Rocky Horror Picture Show.
Are just some that it won't back up. -
i just did Barbershop again and it did the same thing..but i notice that it does it after it complete with the movie and its doing the bouns stuff... it crashes when it processing the packets of the bouns stuff i guess!!!!!damn it :evil:
doesnt back up..
Spy Game - iso or file mode on DVD Decrypter
Oasis - familer to Millions - " " " " -
I love InstantCopy.Especially the customizing ability to deceide which parts of the DVD get the best quality.I like to be able to downsize the extras i don't want and use the extras filesize toward making the movie better.
So far i've backed up 3 movies,and they play great in my apex player.
Left escaping to the right ...
By megadriver in forum AudioReplies: 4Last Post: 29th Nov 2007, 12:50 -
Converting a Mono Left Channel to Double Mono Left/ Right Channel on a DVD
By socool135 in forum AudioReplies: 5Last Post: 16th Sep 2007, 00:45 -
problems left and right
By kukuswish in forum AudioReplies: 2Last Post: 3rd Sep 2007, 16:45 -
Confusing Right with Left...
By Thortok2000 in forum Newbie / General discussionsReplies: 17Last Post: 29th May 2007, 16:30 -
By Thortok2000 in forum Capturing and VCRReplies: 1Last Post: 29th May 2007, 09:50
