I have had some bad luck earlier trying to burn a new box of Verbatim DVD+Rs (reorder 43205). The three first disks becane coasters. Recording proceeded ok until the lead-out, when I was shown an error message (Invalid Field in command - unable to perform disk-at-once operation). Recording failed and the disk was reported as empty, but trying to record on it again showed only 152MB left.
I am using a SONY DRUA and Nero 5.5.9.14.
After a short investigation I realized the drive had a "d" firmware and I had downloaded the latest "g" firmware, just in case. I decided this might be it.
After upgrading the firmware, I tried for the 4th disk. This time I decided to be on the safe side and did a simulation first. Done succesfully, so I decided to have a go in burning it. Nero said couldn't write to the disk because it was read-only and that I should replace it with an empty one.![]()
Examining the recording layer revealed that the disk may really be recorded, so I took it to the stand-alone player for test. It is a perfect disk, the one I was trying to burn for hours.
So from now on, I am going to simulate recordings (rather than risk burning them). Sounds crazy, doesn't it?![]()
Results 1 to 1 of 1
The more I learn, the more I come to realize how little it is I know.
Burning DVD Could not perform end of disk-at-once
By jasonkral in forum Authoring (DVD)Replies: 8Last Post: 14th Feb 2011, 00:05 -
Burning several mpg files straight to a DVD compliant disk...
By vonsworld in forum Authoring (DVD)Replies: 2Last Post: 5th Dec 2010, 07:25 -
Burning to DVD RAM DISK and then play on your TV
By pmorris1 in forum Newbie / General discussionsReplies: 5Last Post: 25th Dec 2007, 19:15 -
Burning x264 files to a dvd disk?
By SLICK88 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jun 2007, 12:19 -
Burning HD 720p to dvd disk.
By compduce in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2007, 02:12
