hi men,
i've got a divx (.avi format) with ac3 audio but with my ibook ( G3, 800Mhz,OSX10.2.3) can't hear the sound.(i 'm using MplayerOSX).
in order to encode my dvds to divx, i'm using Forty-two, and this freeware suggest the output format "DivX Near DVD" High quality DivX File (2000Kbps, ac3 700px wide)
But ,if i can't hear the ac3 audio of the divx with a mac, why Forty-two suggest this output format?
thanks in advance.
Hi,
Would suggest you encode yr DVDS thanks to ffmpegX. check XVID in quick preset and AC3 in audio section. Then you dl VLC here: www.videolan.org and your Ibook will be an happy laptop againKEEP FAITH -
I would try VLC to play your Divx. I don't know why mPlayer wouldn't work, as it does for me. I would just try VLC and see if that works. I don't think it plays as well as mPlayer for Divx, but it still works.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
Rip DVD to Divx/Xvid with AC3 Audio
By dudeman316 in forum DVD RippingReplies: 6Last Post: 3rd May 2009, 03:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
Best (easiest) DVD to (DIVX or Xvid) with 5.1 (AC3) Audio out
By balagan in forum DVD RippingReplies: 5Last Post: 11th Dec 2007, 15:16
