  1. I ripped a the movie "Obro where art thou" with smartripper and then used flask to convert to divx. I used this page as reference http://home.wanadoo.nl/ruud.szwajcer/Divx/index.htm
    My video is fine but as the movie continues, the audio seems to be faster than the video. In otherwords, use would here the audio and then you would see the person say the words. Pretty much out of sync. How do I fix this? please help!!!!!
  2. Anyone out there know how to fix this....
    I would really appreciate it!!!
  3. I'm having the same problem with A Clockwork Orange
    Nov 2000
    Follow these steps:
    Open AVI in VirtualDub, set the Video & Audio to Direct Stream Copy, go to Audio settings & Interleaving set the Interleaving to 100ms & then save AVI again (should only take 2-3min)
    Hope this helps
  5. and how would u do that for a vcd?
