hey guys i need some help i got red dragon divx ac3 audio i was wondering how to keep the ac3 audio after the encode if i run the whole thing through tmpgenc i end up with pcm audio is there any way to avoid this cause it seems that my ps2 has problems reading dvd with pcm audio .
any help will be greatly apreciated thnks in advance
You need to open the divx in VirtualDub. Set your audio to 'direct stream copy'. Then select FILE | SAVE AS WAV. Name it as a .AC3 file (example: reddreagon.ac3 ).
Find AC3FIX.EXE (check the tools section. If it's not there, complain, and then try google. If you still can find it, PM me. You need it to fix the corrupted frames introduced into it when you extracted it with VirtualDub. It will stop your audio from going out of sync.
Encode your avi to M2V (video only) in TMPGenc, or whatever encoder you use. Then use the mutliplex tools in TMPGenc ( FILE | MPEG TOOLS ), or bbMPEG to multiplex the AC3 back in with your M2V video file (I think bbMPEG will multiplex AC3..never tried it..anyone? In either case, I TMPGEnc will)Impossible to see the future is. The Dark Side clouds everything... -
It's dos based. Just type "AC3Fix /?"
If I remember correctly, you type ac3fix and the input filename, and the output filename. you must specify the full path to both if ac3fix is not in the same directly as the AC3 file.
example:
ac3fix c:\temp\infile.ac3 c:\temp\outfile.ac3Impossible to see the future is. The Dark Side clouds everything... -
thnks so much for your help this far i normally author with dvd movie factory it dont support ac3 audio and recomendations on some authoring software that does or anything that will go from mpeg2 with ac3 audio to vobs
thnks in advance for all your help everything has worked excatly how you have said -
Look for SpruceUp. It will let you author DVD's using AC3. The new version of Roxio CD & DVD Creator is also supposed to support AC3. I have a copy, but I haven't evaluated it yet. I just use SpruceUp (note, there is not space in the name. Search GOOGLE for it). It's simple, quick, efficient, and it gives me everything I need.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
Rip DVD to Divx/Xvid with AC3 Audio
By dudeman316 in forum DVD RippingReplies: 6Last Post: 3rd May 2009, 04:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
Best (easiest) DVD to (DIVX or Xvid) with 5.1 (AC3) Audio out
By balagan in forum DVD RippingReplies: 5Last Post: 11th Dec 2007, 16:16
