hi there i ahve tried to convert SVCD to VCD but to no joy. I have followed the guide but it just has not worked. I have also tried the header trick and that just dont seem to be happening for me either, is there anyway i can convert an SVCD mpeg to a VCD mpeg please...thanx
Also when an mpeg2 has been converted to mpeg1 does the size decrease when it has finished converting?
Header trick dont work??? Maybe your doing something wrong. Well what I do is I load Tmpgenc, then I go to File>>Mpegtools. And then you go where it says Simple Multiplex, Load your SVCD mpeg file, then where it sayd type select MPEG-1 Video-CD not the one that say non-standard next to it. There you go!!
hi there i have done that but i still have probs with it... 1 out of 5 moviez have worked but the rest have not.. i would preffer to just fully convert it to mpeg1. i know the quality it crap but they should get a proper dvdplayer not a crap one
... good job i dont use my cds or i would have none left lol
hi, so i was wondering if anyone can helpme please,,,how do i fully convert and mpeg to mpeg1? without doing the daft header trick please,,,thanx
Yes it does, e.g I converted a film clip that was in 77MB .m2v and after conversion it went to 48MB in .mpg. It just depends on how good you want to try and keep the quality.Originally Posted by driver_uk2001
Having problems with mkv conversion
By twiadpaws in forum Blu-ray RippingReplies: 0Last Post: 4th Mar 2009, 13:31 -
Conversion problems
By djtommye in forum DVD RippingReplies: 8Last Post: 16th Oct 2008, 02:13 -
VC-1 Conversion Problems
By UHD4096P in forum Blu-ray RippingReplies: 3Last Post: 23rd Aug 2008, 00:40 -
quality problems after conversion
By blubot in forum Video ConversionReplies: 16Last Post: 17th Jun 2008, 10:08 -
film conversion problems
By hobo20212 in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2007, 07:52
