Im using TMPGEnc
I have this one AVI that is 25FPS. that is a PAL
my DVD player only does NTSC.
I was wondering what would happen if I used NTSC FILM with a 25FPS video?
Another question. I also have another one that is 24FPS. what would that go under?
PLease give me information Thanks in Advanced.
I get perfect encodes with 25 fps PAL avi's. This works for me:
TmpgEnc with a PAL template. ( I use a modified template)
After cutting, I use Nero and burn as a NTSC.
Plays fine in my Apex AD 1500 and Apex AD 1201 set as NTSC.
Had no complaints from anyone else that has borrowed them and used various players. -
Actually, this is a very interesting question. Why don't you try it and view it with a software DVD player.
My guess is that you will get increased flicker (like a slow refresh rate). Less probable is that your player will play them at slower speed (just kidding).
I recommend that you have at least one rewritable disk and do (what I call) proof-burns. Test burn on the DVD-RW and try it on the recorder. It's much cheaper
The problem, however, is what you want to do with the disks. You may have a very flexible and smart player and it may be able to play disks others won't. If that's allright with you, fine. Otherwise, it may be wise to find a friend with a less flexible player (I am told SONY players have built-up a reputation of not playing anything slightly off the beaten track).The more I learn, the more I come to realize how little it is I know. -
What If the Video File is 24 FPS?
What Do I USE?
NTSC FILM or PAL?
because thats like inbetween both. -
I have not run across any 24 fps avi rips. I can't help you there. Possible that it is NTSC film but labeled as 24 fps?
I also assume that you are burning svcd / vcd to cd-rom not dvd-rom. -
<link removed - no warez>
here is a step by step guide to convert avi of any type and frame rate to any format vcd/svcd/dvd
many thanks
dididave -
Guides can be a good thing. This one looks involved. So many different programs and so many diffferent ways to apply them it can be confusing to a newbie.
I get perfect results using TmpgEnc with 25 fps PAL avi's. Luv 'em. NTSC film use to be a little jumpy until I discovered inverse telecine. Now on my NTSC film avi's I just do an inverse telecine first and my results have been great.
I like simple as long as it works. Using only TmpgEnc to encode, bbMpeg to cut and Nero to burn has been as simple as it can get. Every now and then I might have to play with the audio using another program besides the ones that I just mentioned.
If it was me and I had the 24 fps avi, I would simply load a NTSC template, check the inverse telecine box and give it a whirl. Before progressing to the 8 different programs, 12 different steps, 36 hour avi encode, try simple and check your results. If it is compliant and looks good, if it is non-compliant and looks good then keep with the simple.
Anyways as I said, Guides are good but start simple and then move forward.
60 FPS avi - question
By pike8 in forum Video ConversionReplies: 10Last Post: 3rd Jan 2011, 17:45 -
TMPGenc TS FPS Conversion
By leftofcool in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 08:39 -
FPS question
By pfxz in forum Newbie / General discussionsReplies: 3Last Post: 11th Jul 2008, 14:58 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17 -
TMPGenc Xpress FPS trouble
By shorto in forum Video ConversionReplies: 0Last Post: 6th Sep 2007, 18:59
