How do you get a 640 x 352 to be 480 x 480 for SVCD formatbut maintain the same aspect ratio under Mainconcept. I can get full screen with no problem.
Under TMPGENC you have mutiple ways of changing the aspect ratio. one is called "full screen keep aspect ratio" That creates them black bars on top and bottom so you get the widescreen look.
Cannot create widescreen look under MainConcept. Mainconcept codes 3 times faster is 2 times better image quality without the hassles under TMPGENC.(no need to do virtual dub, framerserver, create a wav file...ect)
Help...
MC doesn't have built-in resize filters. If you want to resize and keep aspect ratio, you have to use frame-servers. I use Avisynth to do all the filtering, then use Link2 to wrap AVS script, because MC doesn't read AVS file directly.
if i use virtual dub frameserver and save project as avi not tpr.....where do you make changes in the frameserver to change the aspect ratio?
Starting up a frameserver is pretty easy....but I dont know of any setting you change in Virutal dub to change aspect ratio?
Render settings questions for MainConcept/AVC/AAC (*mp4) in Sony Vegas
By vid83 in forum EditingReplies: 10Last Post: 22nd May 2011, 03:55 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Mainconcept DV Codec in VirtualDubMod
By WinSpirit in forum Newbie / General discussionsReplies: 1Last Post: 15th Dec 2007, 00:31 -
MainConcept products !? use it or not..
By Harviz in forum EditingReplies: 1Last Post: 1st Dec 2007, 21:14 -
Mainconcept DV Codec Vs. The Rest
By SeeNoEVO in forum Video ConversionReplies: 25Last Post: 5th Jun 2007, 09:16
