  1. I recently had to format my hard drive so I had to reinstall everything. After downloading an avi film file , when trying to encode it using TMPGenc I keep getting an error " not formatted or supported" and so it won't let me encode. Ihave nimo codec pack installed but still no luck.
    Jan 2003
    Amsterdam; the Netherlands
    Scan your AVI with Gspot ( tools-section ), to check the codec & framerate. At least install Divx3,4,5, Nimo-pack, Xvid and ffdshow.
    D.C.
    " Check him for weapons..... no; he doesn't need 'm...... he IS a weapon. " -- Return of the Dragon.
  3. Thanks ........... just did everything ...gspot tells me everything is installed and length is correct .......but says video not rendered
