  1. If I installed Nero Burning Rom 5.5.9.14, does that mean that I am using Nero's ASPI in any DVD buring program I use?
    I am having studdering playback in my standalone about 45 minutes into the movie and some people have suggested using a different burning software. So, I used DVD Decryptor to do the burning, but the same thing happened.
    Should I uninstall NERO and install the ADAPTEC ASPI? Then try DVD DECRYPTOR?
    Thanks.
    Dec 2002
    DVDDecryptor doesn't require ASPI. By default it doesn't use ASPI for W2K boxes (for me it doesn't).
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  3. I am using Win XP.
