i have a problem with tmpgenc when i encode a divx to mpeg1;
after 20 or 40 percent i must close tmpgenc because " there is a problem in tmpgenc.exe in kernel32 and tmpgenc must closed"
i tried another divx without problem
i separated audio and video and same problem occured
what s happening?
sorry for my english i m french...
Try checking the divx for bad frames. (look in the guides or search the forum for more info on this)
A simple test:
- Open the AVI file in VirtuaDub,
- Select Direct Stream Copy for Video and Audio,
- Save it with other name.
- Try to compress the new file.
Good Luck. -
I would try Virtualdub Mp3............... instead of regular Vdub. Use Gspot to check for the codec & framerate.
https://www.videohelp.com/forum/userguides/142555.php
D.C.
" Check him for weapons..... no; he doesn't need 'm...... he IS a weapon. " -- Return of the Dragon. -
what is the difference between virtualdub mp3 and virtual dub?
where i can find it
thanks for your help
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
