How would I find out the bitrate of the Mpeg in an already authored disc ?
check if there is an svcdinfo file that contains information regarding the disk. It would be located int he extra folder of your svcd. If there is then anything you want to know you will find there.
You can find the bitrate of any MPEG1/2 file with bitrate viewer (download link in the Tools section).
How to find the real bitrate for an mp3?
By solitaire in forum AudioReplies: 1Last Post: 21st Apr 2011, 07:21 -
How do I find out if my MPEG vidfile has variable bitrate audio?
By cwb in forum EditingReplies: 5Last Post: 22nd Nov 2010, 08:56 -
How to find the video bitrate on a DVD?
By Xavier in forum Newbie / General discussionsReplies: 2Last Post: 26th Nov 2009, 15:42 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 22:23 -
ConvertXtoDVD does it find optimal mpeg bitrate for you?
By supaguy in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 15:13
