    Jun 2001
    Roy, Utah
    I searched the Forums and Found something on making SVCD menus but nothing on making VCD menus can someone point me in the right direction
    Thanks for your Help
  2. http://www.ttool.de/indexe.htm -->Guides-->TSCV Authoring Guides
    With this software you can also make VCD menus.
    Good luck.
    Jun 2001
    Roy, Utah
    What is the Program called that link just took me to there home page if its the TSCV program it said file not founf but if that is the name I could probley find it some where else thanks for your help
  4. Hmm? First, yes you want to d/load TSCV 0.72b rel 7 (IIRC this is the newest one). If you go to http://www.ttool.org and click on download it should be listed there. You'll also need to d/load the newest VCDImager.
    TSCV edits MPEG2 files. To edit MPEG1 (VCD) you'll need to create CDI dir in the same dir you place TSCV?VCDImager. I forget the names of the 3 files but the guides tell you how to do this. Or just copy the CDI dir from nero
    TSCV is a great program, but read the guides first! It's still beta, and if you have problems there's a forum on the site to ask them.
    Jun 2001
    Roy, Utah
    Ok thanks guys I'll go home and try this "at work now" if I have any other questions I'll just post again
