I thought the 15GB of space I left would be enough, as it was for the first disc of the movie, but the second disc seemed to take up more space than available. I think I cleared up enough space to fit the rest of the bin file, but I have no idea how to get it to restart the bin file creation without restarting the whole ripping process again?
If someone can tell me how to continue or restart the bin file creation that would be great.
Also, I have left the DVD2SVCD window open and computer on; I will leave it open until someone lets me know it is ok to close it.
If i was in this situation i would look in my c\programfiles\dvd2svcd\movie-folder and see if the finished mpg was there i would then use vcdeasy to make the bin,cue file
i think it all depends at which stage the program stopped -
Hi,
First of all, It's Perfectly save to close the DVD2SVCD window ! DVD2SVCD has a very nice recovery function.
Second, what you can do to finish the process is go to the directory where you ripped files are and delete the VOB files. This should give you enough space to complete the process.
What DVD2SVCD does is Rip the (AC3) audio, encode to SVCD MP2, re-encode the VOB to a SVCD compliant MPEG2 Stream. Mux the two to one complete SVCD Audio+Video stream, cut's it into 2 or 3 files which are the size of a cd and then creates images.
Since, at this point, you already have the complete SVCD stream and probably the CD-sized files, you do not need the vob's for anything any more. I used this method on my 20Gb laptop many times.
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
Have you tried the recover function? just choose where you want Dvd2Svcd to start from, it should then just use the appropriate point it crashed out, try not to change any settings!
Thanks for all the great advice! I managed to figure out the recover function and had to recut the video, but in the end it did work!
Thanks a lot!
Movie image file how much disc space?
By eriksat1 in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2009, 13:20 -
What if the Matrix ran on Windows
By freebird73717 in forum Off topicReplies: 3Last Post: 12th Nov 2008, 20:29 -
How to create a crystal clear image in "infinite white" space
By RevolutionOfTheMind in forum Newbie / General discussionsReplies: 9Last Post: 25th Oct 2008, 18:14 -
For occupying less space, should the DVD be saved in an image file?
By coody in forum DVD RippingReplies: 6Last Post: 10th Dec 2007, 21:08 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 20:55
