My DVD's will only play on my Apex 1500 DVD player which is macrovision and region free. It wont play on my other DVD player which is a Toshiba SD 2700. I am using DVD Decrypter (also used SmartRipper), DVD2One and RecordNowMax. Anyone know what I might be doing wrong.
THanks
Results 1 to 9 of 9
I had the same problem to...
try to burn the files (VIDEO_TS and AUDIO_TS folders) in Nero in UDF1.02
mode...for me it works!
there is a guide out here in the forum just look for it.. -
Check the DVD player compatability list,your Toshiba may not be capable of reading DVD-R. Many older DVD players will not play DVD-R.
what are you burning with?
I use Prassi Primo DVD using DVD2One.
SmurffTo all those past and present. All those that have fought for our freedoms. God Bless. Those of you that are fighting now,
keep your heads low. Those of you back home hold your heads high. -
Sorry you said before <oops>I am using RecordNow
When I get a dvd that works in some and not others I check the recording program and then the media.
Your burning program is a good one so sorry the only thing I can suggest is to try different media.
Regards
I finally got a working DVD. All I did was use GEAR DVD instead of RecordNowMax. I had used GEAr DVD Pro before and didnt have any problems. The reason why I changed is because the trial expired. Now have to look for cracked version of Gear DVD. Anyone knows how... Thanks
Be sure to set RecordNow to finalize or close the DVD or it won't play. Also some older players may not play both DVD-R and DVD+R media.Originally Posted by juned99
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
