Results 1 to 9 of 9
  1. I HAVE 640MB OF RAM I'M RUNNING A ATHLON 1.4 WITH WINDOWS ME.I RECENTLY DISABLED VIRTUAL MEMORY,AND AM HAVING PROBLEMS ENCODING A FULL MOVIE.ANY SUGGESTIONS
  2. WindowsME can give problems if you use >512 MB of memory.
    You can limit the amount of memory Windows uses by editing the ini file. You can read how on:
    http://support.microsoft.com/support/kb/articles/Q181/8/62.ASP
  3. SO I SHOULD SET THE MAX AMOUNT OF MEMORY TO 512?IS WIN 2000 HAVE THIS PROBLEM TOO?
  4. No, Windows 2000 can handle 640MB memory without problems.
    Feb 2001
    Rhode Island, USA
    Yes, I have 1.5GB of PC133 SDRAM, and I used to use Windows 2000 Professional. Now I am on Windows XP Professional build 2600. In XP you can turn off the pagefile again, and it runs great. In 2K, you cannot turn off virtual memroy, though, you can only custom size it to be smaller if you want.
    irc.webmaster.com port 6667 #DDR
  6. suggestion: stop typing in caps, it's not like we are illiterate.
  7. SUGGESTION TO CONDONE,IF YOU HAVE NO KNOWLEDGE OF A TOPIC,DON'T WASTE THE SPACE.EVERYONE ELSE THANKS FOR THE ADVICE,LOOKS LIKE I'LL BE GETTING XP.
  8. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Condone is correct though, typing in capitals is considered yelling, and not polite. It is also 'harder' to quickly read, which is my main problem with it
    As for your problem, yes Win 2K or (supposedly) XP will be the best for you. I have tried Win 98 & ME with 1GB of RAM added in increments of 256 - at 512MB both 98 & ME were fine, at 768 & 1024, it became a little 'flakely', and was prone to lockups, programs behaving strangely, and other random problems. It is suggested that 512, or a little above, be the max RAM you add to a 95/96/98SE/ME machine
    David
    http://www.horrorking.com
  9. OK ... no ram ?? try to download FREERAM program
    it optimize your memory like defrag to file !!!
    download it at :
    http://www.geocities.com/MPGTOASF
    the file name is freeram.zip
    ok .
    now , before start convert a movie
    click CTRL+ALT+DEL and remove all program except
    INTERNAT
    EXPLORER
    SYSTRAY
    wait until all close
    after that rerun the FREERAM program... click on optimize
    ans wait for a 4 second
    that try to convert .
    if you still have error < ???? > , you may have a memory leak
    ok , try and tell me what happend
    goldenaxe4000@yahoo.com
    bye koby
