Hey guys,
I've been searching through this forum for a while now and i have found lots of stuff till now. What i bascially want is a simple to use dvd author program like DVD workshop that can do motion menus. Workshop is the best but problem is that i can only have a motion menu lenght of 5 seconds. Is that like a bug in the program or something? Also, how do i tell DVD workshop not to convert the DVD compliant video file? I have Ulead DVD workshop V1.0. Does Reel DVD do motion menus?
Thanks.
Rob
I cant answer most of your questions, but i do know one thing though. Easy to use and powerful do not coexist in the same software. Scenarist, Dvd Maestro are powerful. DVDit and DVD Workshop are easy to use. I usually have better luck with Scenarist and Dvd Maestro as they dont crash and spit out errors constantly. Just my 2 cents.
The trial version of DVD workshop has the 5 sec motion video limitation. There are also other limitations in the trial version. The full version does not have any limitations.
AH!!! thats wat it is. Ive tried to use dvd maestro and i cant figure it out. ulead seems to have everything i need. Looks like im off to ulead to purchase dvd workshop. Thanks
Rob
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 10:25 -
Replacement for Ulead dvd workshop 2
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 14th Apr 2010, 23:05 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 03:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55
