  1. How do I change MPEG to MPEG-1 please help, I know im a big newb at doing thing's so if you do know a way please give full details thanx.
  2. Member twodogs's Avatar
    Dec 2002
    Australia
    hmmm. Can you clarify what you mean by MPEG & MPEG-1
    by MPEG-1, do you mean "VCD compliant MPEG" ?
    by MPEG, do you mean sometype of movie with ".mpg" extension of miscellaneous origin, eg: via email, downlaoded from net ?
  3. ok, the file type says MPEG video/audio stream I need it to be MPEG-1 so I could put it on a VCD.
  4. Member twodogs's Avatar
    Dec 2002
    Australia
    Get TMPGEnc, load the VCD template. Drag the MPEG file to the middle of the screen, and hit Start.
    (You might need to change the output file's name too)
    There's a guide under the Convert link to the left (first guide in the list).
