  1. Ok This Is Not Really A VCD Question, But I'm Hoping Someone can Help Me.
    1st Does Anyone no how to install a 'trkwrite.dll' File ?
    2nd I'm Getting a Error in my start up menu ( the menu at the lower right hand bottom of my desktop..... ) It Reads " DriveCD, No Supported Drives "
    I'm Running Windows XP.
    Also Is There A Way To retrieve something that was remove useing 'add/remove program' option in your control panel, I think i may have removed something i wasn't surpose to and now I'm having this problom
    Please Help
  2. hey,
    any file with the "dll" extension doesn't need to be installed. all you have to do is to download it. you have to figure out where it is required to be (usually it is in c:/windows/system3s), just write down the path when the error message you are receiving comes on.
    as for the add/remove thing, you can pick back files if the are in your trash folder. but if you emptied your trash folder, i guess you can't. i read about a program that would allow you to that, but i tried it and it didn't work out.
    maybe someone knows about it better?
