  1. I'm having troubles entering the code sent to me for the update is anyone else having the same issues. It wont take the code that was sent to me. Yes i'm a register user and not not begging for a code, just want to know if i'm doing something wrong!
  2. I was having the exact same problems too! That is until I figured out that you have to download the new program to enter the new code. I was trying to put the new update code into the version 1.0 and it was denying me!
    So download the new version and put the new registration code in and you should be all set. Also remember that if your new code is three lines long you might have to copy and paste each line separately like it said to in the email.
    Nov 2002
    London
    Ive had no problems. Downlooded the new one and updated just now.
    Email the support and ask for help.
    Regards
    Smurff
    To all those past and present. All those that have fought for our freedoms. God Bless. Those of you that are fighting now,
    keep your heads low. Those of you back home hold your heads high.
  4. See I wasn't crazy they released a new ver because outlook could not handle the registration, tho I found out that you have to forward the e-mail and the reg will display correctly oh well good job.
