I have a Pioneer Laserdisc unit (u know those big old 12" discs) that says it can also read CDV format. I think this is some kind of early VCD format that never really picked up. I tried popping a VCD just to see if it would work but no luck, so i was wondering if there is a utility that would allow converting video to that format (CDV) ??
CDV is Compact Disc with Video, something like the enhanced CD's you see out today with music and a couple of video's on it.
I know of no consumer way of recording something on a CD so it will play CDV, I have a Pioneer D704 laser disc thats a side changer with digital and have never found any way to play a VCD or even found a CDV to try out.
sorry -
CDV is essentially a 5" laserdisc (as opposed to the 12" biggies). These 5" discs have audio tracks on them, so you can pop them in your CD player and hear the single.
The video is analog on these discs, just like laserdiscs, so a) you'll spend the rest of your life locating a burner for these discs; b) more good luck to you if you find authoring software!; c) the format is totally incompatible with digital video (VCD/SVCD/DVD) although there are combo-players available (they use different lasers for each kind of disc I believe).
I have one, REM "Get up" but I can't find it. Last time I saw it in my apartment was about 2 months ago. There is a store in the Washington DC area called Sound Images by High Tech, 7700 Old Georgetown Road, Bethesda, Maryland (301/718-2824) that had a handful of the 5-inchers last winter. They may still have some if you're really curious. I'm not affiliated with them in any way, but I was a regular customer when I worked in Bethesda last year.
As a side note, this store also sold 5" Dolby Digital audio CD's from Japan. I'd never heard of it before and never bought one, as I was afraid to experiment with that!
How to convert CDV Files
By roxics in forum Video ConversionReplies: 8Last Post: 29th Sep 2010, 11:47 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 21:00 -
CDV's from the 80's/90's
By ChaunceyK in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2009, 08:16 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
