Using Vdub's mp3 freeze I loaded an Xvid w/wav format mp3. When I choose full processing mode save wav, the process takes one second and leaves a wav file about 1 mb big. I tried de-muxing w/avimux then converting to wav w/toolame. Also if I put the Xvid directly into tmpge and try to use source range, on the second part the audio is not recognized. The Xvid plays fine on windows mp and I scanned for bad frames. I'm wondering if the audio might be corrupt and if so how would you fix it.
I had problems too, I had to:
- save the wav using direct stream copy in VirtualDub
- convert it to normal PCM wav with Nero Wave Editor
And then I got it right and in synch, it becomes a wav file close to a GB though.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
MPEG-2 edit/save, edit/save, edit/save... cycle
By KZemunski in forum Newbie / General discussionsReplies: 8Last Post: 26th Dec 2010, 15:55 -
Isolate Audio In This MPEG-2 File, And Save As WAV (or any other format)
By onesikgypo in forum AudioReplies: 0Last Post: 22nd Feb 2009, 05:14 -
VirtualDubMod and Save WAV problem...
By bla4free in forum AudioReplies: 7Last Post: 9th Oct 2008, 16:53 -
question about "save old format avi" with Vdub
By mr-scarface in forum EditingReplies: 3Last Post: 5th Sep 2007, 22:34
