Using VDub, I'm experiencing frame drops starting at exactly 20 seconds into the capture. The VT adjust starts going from +0ms into the negatives and keeps on counting down. Frames start dropping about 1 to 10 per minute. I've used the task manager to see if any proccesses are stealing cpu cycles at 20s but no indication of that there. I'm using an A7N8X MB, Audigy 2 Platinum with latest drivers, and AIW 8500DV with Catalyst 3.1. I'm tempted to do a clean install of xp and start with a minimum install of drivers then work from there but would like to avoid that if there's an easy fix. Checked the irq's and the sound card is on it's on IRQ, and so is the video card.
Steve
my similiar problem improved greatly when I defragged the hard drive and had it shift everthing to the one end.
DVD frame dropping.
By videosam in forum Video ConversionReplies: 20Last Post: 4th Aug 2010, 04:00 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 09:38 -
Flickering / Fluttering / Frame dropping...is this copy protection??
By mik534 in forum DVD RippingReplies: 9Last Post: 2nd Oct 2009, 06:55 -
Dropping frame with profile H.264
By n69 in forum Video Streaming DownloadingReplies: 2Last Post: 22nd Dec 2008, 21:41 -
is this pinnacle, dazzle or my new PC causing my frame dropping problems
By arthur1971 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2007, 02:41
