Hi guys,
just after some pointers on how to join 2 xvid files together
successfully!!!
any help will be greatly received.
btw the film is xXx - 2 files
thnx all
Providing the files have same encoding settings (fps, audio freq. bitrate, etc) this is very easy to do in vdub. Open the first file, then select file, append file segment and select the second file. Both files will now be consecutive on the same timeline, simply save with a new filename using direct stream copy for both video and audio.
2 xvids codecs in vdub
By catdaddio6 in forum Video ConversionReplies: 1Last Post: 26th Aug 2008, 15:29 -
Joinng mpeg files together
By efiste2 in forum EditingReplies: 1Last Post: 6th Feb 2008, 11:22 -
Is this how to make Hi-Def xvids?
By Topher5000 in forum Video ConversionReplies: 4Last Post: 17th Sep 2007, 15:05 -
Can't get Xvids to work in VDub
By clos in forum Video ConversionReplies: 3Last Post: 9th Jul 2007, 11:47 -
Close Captions Instead Of Subtitles In XViDs
By 888888 in forum DVD RippingReplies: 3Last Post: 3rd Jul 2007, 15:03
