hi men,
yesterday, when i tried to encode my dvd ripped with d-vision ,my terminal let me the following message: "missing name for redirect"
now i can 't "encode" cause my terminal is "BUGging"
i tried too with macdivxcreator but i 've got the same message
the only solution i have is to use DivA wich is not using the terminal but can't rip all DVDs
Can you help me? javascript:emoticon('')
thanks in advance
what is your desired output. There are better programs for dvd encoding.
It depends on your output and what your source file is.
How about more info and ill recommend another program to use
also, what system are you running. All very important -
What is the exact command line you are running? tcsh (the default shell for OS X, as I recall) returns that error message if it looks like you're using the I/O redirection operators (greater-than and less-than) incorrectly.Originally Posted by alexis
here is the command line
tcsh - ttyp1)
[Ordinateur-de-alexis:~] alexisleyravoux% cd /Users/alexisleyravoux/Desktop/DVD>>>Divx/DVision\ 1.2.4/D-Vision.app//Contents/Resources/; ./ffmpeg -i /Users/alexisleyravoux/Desktop/vanity\ 9/Track01_00.m2v -y -map 0.0:0.0 -f avi -vcodec mpeg4 -me epzs -b 900 -r 25.0 -s 756x570 -g 300 -qmin 2 -qmax 10 -hq -an -benchmark /Users/alexisleyravoux/Desktop/clip/Film\ cible.avi
Missing name for redirect.
to encode my file.mv2(video "vanity 9") , i used D-vision. -
I think that "DVD>>>Divx" directory is your problem, > is a special character to the shell. If you want to use it in a file or folder name on the command line you should put a backslash in front of each > character. Or put the entire directory name in single quotes and don't use any backslashes.Originally Posted by alexis
Batch convert AVI to MKV on Mac from terminal?
By hogfan in forum MacReplies: 5Last Post: 19th Nov 2014, 20:19 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
using the dd command in terminal to backup DVDs
By redishdog in forum MacReplies: 10Last Post: 24th Nov 2010, 20:46 -
How to use Hyper Terminal in TCP/IP(winsock) mode to communicate ?
By SingSing in forum ComputerReplies: 14Last Post: 31st Aug 2008, 08:37 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
