  1. On only fools and horses series 5 theres 8 vobs ,VTS_01_1.VOB > VTS_01_8.VOB,in these vobs are the 6 episodes.
    How would i go about ripping this so that 3 episodes are on one disc and 3 are on another??
    If i used ifoedit,vob extras,strip vod ids and removed the ids that the 3 episodes i wanted to remove have would that rebuild it so that 3 on one 3 one another.
    Or would i need to do more other than just strip ids.?
  2. Member wulf109's Avatar
    Jul 2002
    Rip each episode to a separate directory as one large file. Demux each into m2v and ac3. You should then be able to author tree episodes to DVD with SpruceUp.
  3. MMMM could do,but as its a series i wanted to keep the menu,this way i could select which episode to watch.So i thought using Ifoedit there must be some way to just strip out the episodes so i could get 3 on one disc and 3 on a second.
