Has anyone here tired 99 minute CD-Rs ? Are they compatible with most DVD players ?
I'm thinking about buying a few to test with SVCD & CVD movies....
Cheers
Results 1 to 9 of 9
Can I assume then no one here is using 99 minute CD-Rs or is not contemplating on using them ?
Cheers -
One word: Proprietary
That means they aren't compatible with squat, just the proprietaty CDRW drives that burn them, nothing else. Kind of like a DVDRAM cartridge or an LS-120 disk, usefull but it's not going to be used in other drives/players.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Hello kenmo!
Actually I use the 99min CD-R's. I don't mean to contradict Gazorgan here, but I believe he is thinking of the newer CD-R media. The 99 min CD-R's are infact not proprietary. There may be some compatibility issues though. I can burn a 99min CR-R with my Lite-on using Nero for overburn. They playback in my APEX 5131 just fine.
When I was making VCD's and SVCD's I would use them. I really liked them b/c I got a little better quality for a movie on 2 disks. I believe I got my 99mins from CompUSA. That is the only place I could find them at a retail store.
Later,
Tearren -
use them alot for dvdrips, vcds svcds, have to agree with tearren, no issues with apex 1200 . dont think compusa sells thme anymore @ least not in NYC. try it out. bloo
I use 99 min cd-r's. Works fine in my three players (Apex 660, Pioneer 353, DMTech 2000).
I order them from: www.AllMediaOutlet.com
If you are going to buy a new player, take a movie burned on a 99 min cd to test in the player. If it plays, make sure it plays the last 10 minutes. Why? The DVD-rom drives on my computers will not play the last 5 - 10 minutes. Not sure why. Although, it could be a problem with PowerDVD.
You can always use them as 90 minute cd-r's if you cant play the full 99 minutes.
wway -
I Use 90 and 99min CDR's, but mostly 90 right now, cause i've got a 6 years
old DVD Player (Pioneer 525) and it doesn't play 99min, but all the new DVD
Players do play them.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
How to upload more than 10 min on YOUTUBE
By 3thman in forum Video Streaming DownloadingReplies: 5Last Post: 6th Mar 2010, 14:59 -
Why does it only convert 15 min. worth?
By woodcliff in forum ffmpegX general discussionReplies: 1Last Post: 12th Dec 2009, 20:11 -
Last few min of AVI being cropped out
By Mr_Del in forum Video ConversionReplies: 1Last Post: 15th Mar 2009, 08:59 -
4 min movie conversion
By Tahir Ramzan in forum Video ConversionReplies: 2Last Post: 3rd Jan 2009, 00:46 -
Replaying a 10 min section
By elute96 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 14:03
