  1. Hey, I can't load divx files in TMPGEnc. I did install the codex stuff for it but it still doesn't work. Could someone help me out with this?
  2. Download Gspot (you can find at Tools) to see if you have all the correct Codes installed. This program will tell you which codecs you need in order to convert / view the movie
  3. Thanks a bunch. I'll check it out!
    Aug 2001
    San Francisco
    I used GSpot to analyze my .avi file, and it said everything was fine. I have all the necessary codecs installed on my system, but there is no audio in the file.
    Any other suggestions?
