I thought this would be the best place to ask some questions as I am new to all this. I have decided to go for recordable DVD now that it is relatively affordable, mainly for transferring old VHS stuff and also for backing up/archiving PC data files.
I have made the first purchase - a 120GB hard drive to go with my existing 75GB, but I still need to sort out the hardware for capturing & recording and I want to avoid expensive mistakes. So any comments/advice on the following would be appreciated:
The DVD writer I had in mind is the Sony DRU-500A as it supports all formats other than DVD-RAM. I haven't seen any negative comments on it so far....
At the moment I have a Win-TV card which can do analogue video capture but not encoding on the fly. So I need a graphics card which is able to do the latter. I do not want to have to record to PC then spend hours encoding files before writing to DVD. I like the look of the ASUS V9280S - will this do what I want? Are there any better/cheaper alternatives that I could consider? I am a bit unsure about how the VCR would connect to the capture card - my VCR only has SCART output, presumably there is a special cable required?
This may be a dumb newbie question, but is there a way of recording straight to the DVD in real time from VHS without having to first create a file on the PC?
I'd be grateful for any comments on any of the above.
There are alot of new program's that do encoding very fast. I do both and with DVD2one encdoing is fast then capturing. Now to author a DVD take's about 15 or 20 minute's you do this after you capture now I would rather do a encode with DVD2one it encode's in 17 minute's and make the vob file's to burn with nero. Now instantcopy 7 even make's copies with menu's take's me about two hour's for a two hour movie to encode about the same as encoding. I would only do capture if you want stuff from TV or old VHS tape's you need to back up. For captureing I love the Dazzle 2 go to this website site Dazzle 2 might have problem's with some AMD mother board's http://stop.at/dazzle2 also WinPVr 250 and 350 are very good. Also i like MPEG2VCR for video editting
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Which of these two capture cards are better for VHS to DVD?
By nomad2224 in forum Capturing and VCRReplies: 14Last Post: 23rd Sep 2009, 10:05 -
Help with Video/Capture Cards.
By drsimp12 in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2007, 07:05 -
Interferance on capture cards
By Signal in forum Capturing and VCRReplies: 35Last Post: 13th Sep 2007, 22:26
