sorry if this was asked before, i couldnt seem to find anything about it...
instead of having the output of bin/cue files for a vcd in forty-two, is there any way i can just get a standard vcd .mpg? and if not, is there any other easier way to do this (besides a totally different process- like ffmpegx for example)?
i thought an older version of forty two had it this way but i dunno...
someone help me out plz! thanks
-Tolly
forty-two should leave the .mpg, .mp2, and .mpv in the temp folder. at least it does for me.
Hi,
if you have .mpv and .mp2, you're at one little step of .mpg : just mux them with any dedicated tool (ffmpegX, MMT or MoreMissingTools etc...)
Well, by reading all comments it seems we often have different results from one user to the other : I can't get a ready to burn image, only (as for you) .mpv and .mp2. Even .mp2 seems is uncomplete in my second trial (out of a PAL DVD). Surely this will be fixed in the future, unless it's the audio source which has a problem (but I doubt, I tried 2 DVDs).
Hope this helped.
Forty-Two requiring I install BSD Subsystem on Leopard
By Berkey in forum MacReplies: 6Last Post: 12th Dec 2007, 11:13 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
