I have been having a lot of trouble with my Pioneer A04 burning my DVD-r's. I am using Pinnacle Studio 8.0 and the rendering process is working fine (belive it or not) and the burn seems to work OK. BUT when I try and play the DVD-r back in my DVD player (and about 5 other brand new models that I tried at the store) the audio gets screwed up near the end of the disc (all crackly but video is fine). I thought it was the media at first but have tried 3 different types of DVD-r's as well (Pioneer, Verbatim and Memorex). I am wondering if there is any way to tell if there is a problem with my burner? Any help would be greatly appreciated.
I should also mention that after I render the files and create the DVD structure and play it on my hard drive using Power DVD, the .vob files play flawlessly. It is only once I burn the video to the DVD-r that the audio problems surface, that is why I was suspicious of a problem with my burner.
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Bad Hard Drive?
By mccoady in forum ComputerReplies: 53Last Post: 3rd Apr 2009, 19:47 -
Bad hard drive, or something else?
By capman21 in forum ComputerReplies: 4Last Post: 23rd Aug 2008, 02:59 -
Bad Hard Drive - Not!
By videobread in forum ComputerReplies: 4Last Post: 11th Sep 2007, 15:47 -
Can't format = bad drive?
By bevills1 in forum ComputerReplies: 25Last Post: 11th May 2007, 17:01
