Im new at making good menu's (non Nero menu) How can i make a still image into a 5 to 10 second avi or mpeg. And be able to add text to it. Please respond... Or email me
LilemanGuest
If you want to create a 'still' as a 5-10sec. avi/mpeg, then you're no longer got a real still but just a movie, playing 1 image for its duration.
You can create such using VDub (Virtual Dub). Al you need to do is load the image and save as an avi (and something more, I don't know precisly because I maky mine using Premiere which isn't free btw).
If you want to create a _real_ still, then I suggest you use software which are designed for such. For instance, VCDwizard has a STILL-Generator build in. All you need to do is loading the image (a JPeG, PPM, BMP, TGA or GIF) in the STILL-Generator (image must be having tv-bounderies, like 704x480 or 704x576), then select what type of STILL you want to have (mpeg1 for VCD or mpeg2 for SVCD) and when you've clicked the Start-button, you'll get your still after a few seconds...
cu.
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 06:38 -
Issue with captured video: 673GB AVI = 4.19 sec??
By photodyer in forum Capturing and VCRReplies: 6Last Post: 27th Jan 2011, 03:06 -
Divx (.avi) movies with 5 sec audio delay - can these be saved?
By Hank Kinsley in forum Newbie / General discussionsReplies: 2Last Post: 19th Nov 2008, 22:20 -
image to avi
By Shaorin in forum Newbie / General discussionsReplies: 3Last Post: 8th Apr 2008, 09:43 -
Padding out avi files to 25 frames per sec.
By yowie in forum Newbie / General discussionsReplies: 8Last Post: 12th May 2007, 08:52
