I'm trying to capture from an analog camcorder, through a Visiontek Xtasy Everything, using VirtualDub set according to the articles on this site, to a 5400rpm 30GB WD HD after defrag. I've even created a separate "Capture" configuration which disables every program not required for capture. I'm still dropping way too many frames.
Do I need to upgrade to a 7200rpm HD used exclusively for capture? Is there another blatant mistake in my profile or setup that I'm not seeing?
The whole point of this process is to transfer the videos I have on 8mm and VHS to VCD.
Thanks in advance.
What capture codec are you using and what resolution? MJPEG at 90% is not drive intensive as opposed to Huffyuv.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I tried HuffyUV and MJPEG, at 29.97fps, starting at 352x240 and reduced all the way to 160x120, still with dropped frames.
What resolution, fps, etc, should I use for optimal TV/VCD viewing? That is, after I can capture properly. -
I think your dropped frames don't have anything to do with your drive. You should be able to capture 352x288 @29.97 fps in MJPEG standing on your head.
I would look for updated drivers for your capture card. I would also try IUVCR (free 30 day trial). I have never had good luck with VDUB capturing, in fact i've never got it to do a decent job. With IUVCR I cap at 720x480 @29.97 fps in huffyuv or mjpeg at 95% and never drop a frame.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Hard Drive: 80GB VS 500GB. Defragmenting and formatting speed.
By vid83 in forum ComputerReplies: 36Last Post: 6th Feb 2012, 13:58 -
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard drive speed problems
By toby223 in forum Capturing and VCRReplies: 3Last Post: 17th Jul 2008, 05:50
