Hi,
how to recognize a file it's a PAL or NTSC format ?
and how to convert from PAL to NTSC ?
let me know any easy tool other than Tmpge ?
thanks in advance.
PAL = 25fps
NTSC = 23.976fps, 29.97fps
TMPGEnc is the easiest tool of them all."I´m not popular enough to be different" -
If TMPGenc is easiest, then how do you do it?
I have a PAL .avi file, and I chose the DVD(NTSC) template. Will that automatically convert it to NTSC, or is there something else that I need to do. I already extracted the audio using VirtualDub, so I don't think that should be a problem.
Is there any other settings in TMPGenc I should be concerned with?
Thanks!! -
Originally Posted by BrianK
https://www.videohelp.com/forum/viewtopic.php?t=78178&highlight=
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL aspect ratio 2.35 format to 16:9 NTSC
By chowa in forum Video ConversionReplies: 7Last Post: 2nd Feb 2008, 17:16 -
.mkv contains PAL format video, I need it to be NTSC!
By kalii2 in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2007, 04:14 -
using pal material to work in an ntsc format
By rapidondamove in forum MacReplies: 2Last Post: 7th Jun 2007, 16:22
