i have encodeed 2 films with unlead 2 now and both dvd have turned out with out any sound any 1 got any ideas wot im doing wroung
I'm sorry to tell you that you're not the first and certainly not the last one to being this issue up.
If you search the forum you will find a great number of posts in which, more or less, this question is being asked.
I have myself over the last few days been looking for a solution to this problem but without success. It seems that there either is no solution, or, if there is one, it's a well guarded secret not to be shared with just anyone.
TL -
i was going to try and use replace audio, have u tryed it TheLarch
coz if u have and it dont work well they ant no pint in trying -
Do you mean no sound when you listen with your set-top DVD player or do you mean when you listen to the DVD on your PC?Originally Posted by mark845
Ulead MF2 doesn't force you to use PCM audio and will let you do a DVD with MPEG audio. Now some (30%?) DVD players don't accept Mpeg audio, only PCM or AC3.
Use TmpgEnc to extract your audio as PCM (basically uncompressed WAV file). Use the "replace audio" button of Ulead MF2 to load this PCM file and see if it helps.
Mario -
thers no sounp on the pc dvd player and my stand a lone, im gona try that "re-place" audio c if that works i'll let u no if it does
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 13:22 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 11:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
