Someone mentioned if you are having problems with alot of coasters, change your transfer rate method from dma to vio. I thought it was the other way around? Which way is better?
Thanks.
Results 1 to 1 of 1
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 14:45 -
Weird Doings in PIO - DMA-ville
By Seeker47 in forum ComputerReplies: 13Last Post: 28th Nov 2008, 13:15 -
DMA PIO Reg Prob Key Deleted returns after reboot
By tonib95 in forum ComputerReplies: 14Last Post: 4th Feb 2008, 10:23 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 22:35
