If any of you have downloaded a movie from Morpheus, you know that they are mostley in AVI format because of the smaller files size. When I reencode these to mpeg-1 using TMPGENC, I get.....you guessed it, Macroblocks. However, I've also downloaded movies already in mpeg-1 format and those videos seem to be high quality, the same as there AVI counterparts. I've tried every setting imaginable on TMPGENC with no luck. How are these guys getting such good quality?
your not alone mate I get the same problem.
If anyone can help us with this it would be gratefully appreciated (I also download most avi's off morpheus/kaaza).
Gav
Ok I myself dont wait 4 replies
go to the mwnu called "OTHER" on the left of the screen, go to the "TOOLS" section, scroll down tuntill u get to the "TEMPLATES 4 TMPEGenc" section u will see the download that removes the macroblocks off AVI,VCD template, just use that
Gav
<font size=-1>[ This Message was edited by: gav on 2001-09-06 23:19:38 ]</font>
Best way to play Downloaded 3D Movies
By mafioso22 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Feb 2012, 12:22 -
What Program will convert both DVD and Downloaded Movies ?
By JMGrande in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2009, 15:46 -
Viewing downloaded movies
By orangekrush in forum Newbie / General discussionsReplies: 8Last Post: 16th Dec 2008, 03:10 -
How will HDCP affect downloaded movies?
By EatMoreChickens in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Jan 2008, 09:31 -
storeing my downloaded movies as data
By dgavob in forum Newbie / General discussionsReplies: 20Last Post: 10th Nov 2007, 00:21
