EVERYTHING SEEMS EASY BUT AFTER THE ENCONDIG A MESSAGE APEARS ON NERO SAYNG C:\MOVIES ETC DISK IS FULL.
THE FILE I WANT TO BURNE IS 300 MG AND I HAVE 2G FREE ON THE HARD DRIVE.
I NEED HELP.
Okay...it doesn't matter how large the divx file is, what matters is how long it is...I don't use nero myself, never have much success with it so I don't know about whether it'll convert the divx to vcd all in itself...but assuming it can, the video has to be no longer than 70 minutes if it's a 650 MB CDR and no longer than 80 minutes if it's a 700 MB CDR...
when the encoding board apears it says
compilation----video1(mode2/xa) 55:22:58
videocd 487mb
the cd is 74m/650mb
i dont get it.
is there a another way to burn a divx to vcd -
tma,
From experience of many people never encode with Nero (bad work).
Nero is very good to burn and to make simple menu.
Use TMPEnc for encoding from Divx to VCD.
Bye. -
final question.
im using tmpenc 12.j
but when i try ti open the divx.avi file a message pops up that says that the file is unsopported.
what now.
are you sure that you have a divx codec like 3.11 installed? does the divx play in the windows media player? i recommend that you separately encode the audio and video, then mux together....there are many methods to do this
I got the same problem as tma mentioned. I don't know why. The divx.avi can be played in the windows media player well. When converting, message"unsupported file" comes out.
Anyone please help? -
OK I think I know the problem,
the divx (I reckon) has audio encoded for div - x ie compressed so basically it can't be uncompressed on the fly and burnt - I reckon NERO probably just telling you size of video stream only. Remember a normal film is one and a half hours so when you "blow up" a div-x to mpeg it will be longer cos it aint so compressed - normally needs two vcds for one film because of this.
You can fire up virtualdub and load in the div-x then set the audio to non-compress and leave the video the same - pobviously make sure you lock audio to video as per settings. Save as AVI this will save a bigger div-x type div-x but with non compressed audio - be wartned the audio size will be bigger that the video hence it could very well be bigger than you'd like. It could also take upto 4 hours to do - depends on your system I guess.
Once you have the new encoded avi use TMPEGEnc to encode as an mpeg, use vcdcutter to splice in half and burn both halves as vcd's using the nero template and voila a div-x sourced film you can watch on your standalone.
I rip in real time to my asus and always encode the audio uncopmpressed (CD quality PCM) and with the video compressed using div-x and then convert as above - results are good.
Regards
scattergun
Converting DIVX .AVI Files to DVD using Nero Vision 8 and 9.
By nnhood in forum Authoring (DVD)Replies: 2Last Post: 26th Jun 2009, 19:09 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 14:17 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
consolidate vcd files with Nero Vision, but problem with playback
By slh888 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2007, 17:36
