Hi,
I have posted this a while ago and have played around with the file since then but I can't find a solution. Sorry, I am a newbie.
So, here is my problem again:
I downloaded a mpg file which seems to be ok regarding audio-video synch. But when cutting out a part of it using TEMPenc or VirtualDub the cut part is out of synch. Thinkiing about it when playing the original file in VirtualDub it's out of synch too.
KingJohn said: "I guess you mean when you play back the original mpeg it "looks" ok If you never made the original mpeg, then it does have problems, that need to be fixed before splitting can be done."
So, how can I check for bad frames and how can I fix that if this is the reason for the problem? Could it be something else?
KingJohn's Guide to bad frames V2 VBR Update is not available.
Thanks,
Gwion
The help files of TMPGENc report any external file imported and clipped/jined etc. will more than likely have video/audio sync issues.
I can't solve your issue, it involves removing the audio from the video and has never worked for me.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
audio and video not in synch by a second or two problem
By sabathiel in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2011, 21:45 -
Webcam video (.mov format) audio synch help needed
By chrisj in forum Newbie / General discussionsReplies: 0Last Post: 23rd Mar 2011, 17:55 -
audio synch problem VOB to MPG
By ajmsnr in forum ffmpegX general discussionReplies: 1Last Post: 6th Dec 2008, 04:06 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47 -
Trying to sync audio with edited video, problems with encode....
By Jensen in forum EditingReplies: 1Last Post: 5th Jan 2008, 08:20
