I don't remember if I asked about this before, but is there a way to make the TMPGEnc Wizard load the 'Expert' settings from one of the preset .mcf files? If not, what's a logical way to be able to use the wizard and have whatever 'walkthrough' you use have the settings of one of those preset files... The reason I'm asking this is that for example an NTSC VCD doesn't have the same settings as the 'VideoCD (NTSC).mcf' template... This includes changes such as Full screen keep aspect ratio (which is good, well usually) to in the VCD Wizard it has just Full Screen (which is bad b/c then it distorts the picture as you know)... Am I stuck just using the featureless old fashioned way of loading the settings file and then not knowing how big the disk is etc.?
Okay, never mind about my last question. What I need help with is this: I choose to make a Standard NTSC VBR SVCD. It ended up making two files, one being 789 MBs and the other 794 MBs. Which one is the right one or did I do something wrong?
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Best Settings
By devdev in forum DVD RippingReplies: 2Last Post: 26th Jan 2009, 10:46 -
HD Settings
By kiwikiwi in forum EditingReplies: 9Last Post: 13th Dec 2008, 16:20 -
What are Camstudio best settings
By jace89 in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 14:36 -
problems with video image settings
By BDawg in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2007, 19:50
