  1. *Fixed some small issues with the IFO files. This should fix the following problems:
    -Trial version didn't work correctly with Sony DVD players.
    -Some players had problems with NTSC/PAL mix in the IFO.
    -Some players stutter on the point of the original layer break when 'layer break bit' is set.
    *Added much asked feature to choose the destination size.
    *Added multi-language support (thanks to everybody who made the translations! ).
    *Added support for CopyToDVD.
    After processing the result can be directly written to DVD±R(W).
    This will automatically deliver a 100% compliant DVD-Video disk, no need to worry about proper settings, directory, file and disk names
  2. can it be used to put 2 movies on one disk now?
