ok
i have downloaded 2 movies (The Art Of War and The 6TH Day) and when i try to play them they wouldnt work so i Tryed DIVFIX which worked and made the movies work on my computer but with BOTH of the movies it said it has errors at certain frames but the movie still plays
so then i try to encode them using tmpgenc to vcd and it would work for some reason so i then open the movie using virtualdub and virtualdub either wont open it or it says MOVIE MAY BE SLOW or some shit like that
PLEASE HELP THANKS
Results 1 to 1 of 1
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 17:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 03:39
