I just recently started burning DVD backups (just switched from SVCD). I've got the procedure down pat, currently using DVDDecrypter & DVD2ONE. For burning, I've tried 3 different methods and all seem to work fine for me. I've used Nero, RecordNow Max, and IFOEdit/IMGtool to create an image and burn with DVDDecrypter.
While all the methods seem to play fine on my Apex AD-660 player, I know I'm going to be sharing stuff with friends. Therefor, I'm looking for what would be considered the most COMPATIBLE method of burning DVD-R's, ie will play on a wide variety of standalone players, including Xbox. I've always used Nero for my SVCD's so I'm familiar with it, at least until I got into DVD, I didn't realize there were so many format choices, and I don't know the differences or which is the best format to select. I tried one DVD UDF/ISO with Nero, and it worked fine. I burned a movie with RecordNow Max, works fine. Did a few with DVDDecrypter (from image), works fine. All work for me, so I cannot make an educated decision for the best one in order to stay as compatible as possible with my friends variety of players. Any advice would be appreciated!
One more question. If I burn a movie one way which works for me, and later discover that I need to burn it another way for a friend, can I simply rip my DVD-R and then re-burn it with another program to hopefully work with theres? Or would it be too late at that point?
Hi,
Ive spent the last week looking into this. I have tried 10 different DVD-R discs and 4 different programs and 4 different DVD players.
To sum-up your problem. I have chosen Prassi Primo
Regards
SmurffTo all those past and present. All those that have fought for our freedoms. God Bless. Those of you that are fighting now,
keep your heads low. Those of you back home hold your heads high. -
Upgrade to Nero 5.5.10.0 and follow the wizard. I've had 100% compatibility on my and my friends DVD players - you just have to make sure that the media is regognised.
Regards,
Rob
Program compatible with cce
By djgazzabhoy in forum Video ConversionReplies: 7Last Post: 27th Dec 2011, 23:20 -
Are cookies considered malware?
By alegator in forum ComputerReplies: 6Last Post: 8th Jul 2009, 17:24 -
DVD burning software compatible with vista
By toolady in forum ComputerReplies: 6Last Post: 9th Oct 2008, 15:06 -
Vista compatible program?
By smudger2468 in forum Video ConversionReplies: 4Last Post: 31st May 2007, 17:09 -
Whats the best DVD burning program out there?
By Tielurr in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 19:21
