Hi All,
I've been trying to get RecordNow DX v4.11 to burn my DVDs. It seems like it should be so easy but I have yet to get it right.
Here's what I do:
Start RecordNow
Click on "Data" in the toolbar
Change the "Volume Label" to my own label
Set "Multisession" to New Volume
Click "Add Files and Folders"
I add my VIDEO_TS folder from a DVD Maestro compiled DVD.
*at this point the "Folder or File as on Disc" shows my VIDEO_TS folder in red*
The "Source" Dir is correct
I click the Record button
It looks as though it may start but then terminates saying "Job 1 failed"
Anything wrong in my setup? I am lost here as this fairly straight foward.
I have my VIDEO_TS Folder of a DVD Maestro compiled DVD. I drag that folder into the workspace of RecordNow DX and
I'm getting en error that says the file is too large and it stops before it starts.
The VIDEO_TS folder is exactly 4.37GB (made from DVD2ONE) -
I have had this problem before, it means that whatever is in the VIDEO_TS file is not ready to be burned as a movie (ie. there are errors). Try changing the name of this file and it will burn it, but it wont play in your standalone. sonething in the movie file needs to be corrected.
thanks for the help axlish. the folder size was actually under 4.37 but I am wondering if IFOedit did something wrong. I was actually trying to get 2 movies squeezed into one dvdr.
Hauppauge 1212 Won't Record Over 40 Min.
By thebigpuma in forum Capturing and VCRReplies: 5Last Post: 22nd Dec 2011, 13:21 -
Stand Alone DVD record Won't Play on PC?
By rkersh409 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 26th Jan 2010, 12:23 -
Formats to 20% door opens and it won't record
By Meggie in forum DVD & Blu-ray RecordersReplies: 9Last Post: 2nd May 2009, 22:17 -
Phillips DVDR3575H 37 won't record OTA??
By Gritz in forum DVB / IPTVReplies: 5Last Post: 2nd Apr 2008, 09:11 -
My Funai DVD Recorder Won't Record?
By rhem in forum DVD & Blu-ray RecordersReplies: 12Last Post: 15th Aug 2007, 14:08
